1jz swap into SC300 fuel feed line leaking and wont stop!
I spent about three hours today trying to get my fuel line hooked up to my 1jz motor. Needless to say I stripped both the 2jz fuel feed banjo bolt and the 1jz banjo bolt in my various attempts and re attemps at getting it hooked up. The banjo bolts were identical between the 1jz and the 2jzge engines when I compared them to each other....But no matter how tight I tightened the bolt into the block fuel would still seep out the back of the banjo fitting and run down the fuel line and dripped constantly. I finally gave up after being soaked with gasoline and getting a few facials of it as well I got the second stripped bolt out and tied the fuel line up.
Is there something I am missing? I have read and re read alost every 1jz build thread on the net and never remember reading anything about the fuel feed lines not hooking up right.
Anyone with some help on this? I am frustrated to all get out on this. A total waste of 3 hours and 2 more googling it thinking someone has had to have had this issue before...
I can take pics or explain myself better if needed ...just ask... Thanks!!!!
I only had one washer on there...I tried it on both sides and it leaked... I have to get a new bolt now anyways so I will be sure and get two washers when I get the replacement bolt...So it should just hook up no problems then like I thought? It has got to be the washers then.
Thanks Ali
Thanks Ali
I picked up a pair of the washers at y local Lexus dealer and also got a new banjo bolt. I finally got it installed Tuesday and no leaks this time... And as far as the laying in gas for too long comment goes..My hands, arms and back all got a nice soaking in fuel....nice tingly burning feeling and instant dry skin...lol Not fun! Would not have been so bad if I hadn't been trying to route the fuel line around the oil dipstick instead of behind it like it goes...Once I figured that out it went in in a few minutes... Must have messed with it and dropped the washer that seats up to the block at least 50 times....Annoying!!! lol Thanks for all your help though guys.
norcal2jz
Performance & Maintenance
11-21-13 02:28 PM
