Help!!! Calfiornia my SC300 did not pass smog test???
Old 03-11-13, 11:33 PM
miraluna
miraluna's Avatar
Default Help!!! Calfiornia my SC300 did not pass smog test???
Today I took my 92 SC300 to get it smogged and it failed badly. I need some help on what to fix. The smog technician said to check up on the o2 sensors which I replace like 3 years ago(??) or cat converter / egr valve... my other mechanic friend told me egr valve is working fine...
what are some other things that i can do to help lower the emissions to pass? Here's a pic of the results. Please let me know what I can do. Thank you in advance.
Old 03-11-13, 11:50 PM
GTX580
GTX580's Avatar
if yr cat and o2 sensors are cool then i would check timing, clean maf.
Old 03-12-13, 06:46 AM
2jznosht
2jznosht's Avatar
Probably hollow cats like my 93
Old 03-12-13, 03:55 PM
Supruxes
Supruxes's Avatar
Move to a state that doesnt do smog testing?
Old 03-12-13, 05:13 PM
PseudoK
PseudoK's Avatar
did you drive the car around to warm up the cats?
I have heard running alcohol mixture with your gas right before going in works, might want to look that up..
Old 03-12-13, 05:57 PM
turbodremz
turbodremz's Avatar
Holy crap, thats an epic fail. I would definately check the cats and o2 sensors.
That failed worse than my car with no cats...
Old 03-12-13, 08:31 PM
miraluna
miraluna's Avatar
thanks guys... i happened to have extra o2 sensors laying around... will change them first...
Rayyan
05-10-18 06:15 PM
LilMan23
02-10-12 03:19 PM
SC4-94
Maintenance
08-14-06 03:33 PM
Vmoney
GS - 1st Gen (1993-1997)
04-13-06 07:02 PM
Quick Reply: Help!!! Calfiornia my SC300 did not pass smog test???
