Borg Warner s366 oil 90 deg adapter thread size
03-12-13, 06:55 PM
The turbo came with 90 degree adapter already. Does anyone know the thread size it's pretty big like 1/2 to 7/16 thread. Thanks
03-12-13, 07:00 PM
Also the bolt thread for the oil drain.
03-13-13, 12:22 AM
remove the 90 degree adapter i cant remember the size but if you do a search on the bws366 quickgs posted what the size was.
03-14-13, 12:56 AM
jwin,
Did you get your BW from ebay seller bensmed? Thinking of getting one too.
03-14-13, 01:45 AM
boostlab. I made an offer and they accept it
03-14-13, 07:46 PM
I think you have your answer on the feed fitting right?
03-15-13, 01:43 AM
^^^ I haven't yet but I haven't really pursued it yet either. In the process of getting a different transmission. I will come to the oil thing later.
03-15-13, 07:35 AM
Assuming my 84-75 is the same center section as yours, the feed port is 1/4 NPT. My drain used a drain flange held in place by two bolts. I think I have an extra one laying around if you'd like.
03-15-13, 01:47 PM
I think we have the same center section as that is how many is configured as well. I have the flange on the bottom already. Thanks for offer. I think I want to run a hard line.
propcop
03-29-16 09:38 PM
xspsi6
Performance & Maintenance
08-22-12 04:51 PM
Starfire07
05-24-11 02:24 PM
broda805
SC- 1st Gen (1992-2000)
01-19-11 08:43 PM
flexspeed
15
08-18-09 07:48 PM
90 ,
adapter ,
bolt ,
bolts ,
borg ,
clublexus ,
dimensions ,
drain ,
feed ,
fitting ,
flange ,
line ,
oil ,
s366 ,
warner
