Weird noise on start up???? Added a video
1993 SC300 Auto
Car is pretty much stock. When I start the car for the first time in the morning or after its been sitting it makes a metal on metal contact sound. I thought it was my power steering pully. and not the case swapped out the whole pump and still got the issue. Im stuck!!!! o yea as soon as the car has warmed up i can turn it on without making that noise. so im just a little worried. Can anyone help?
yes. but i wont do it after the car has warmed up. if i shut the car off after that first start. lets say i let it run for 5 minutes for the first time of the day in the morning. i can shut off the car turn it back on and it wont make the noise anymore until i let the car sit. which would be after i get off work i start the car nd makes the same noise. very strange
just did the timing belt nd accessory less than 6 months ago. i did notice the timing tension pully was loose though. tighten it up but not to much spring action left to it. could it be that? im about to do a full gasket set on the car. im also wondering if its the clutch fan? its like a ball bearing kind of sound if you can. i tried covering my ears everytime i start the car. sometimes i think im going to throw a rod through the block.
Belt and pulleys are good. just a little freaked out. i know the sound of rod knock and some other noises. but on rev the car doesnt make the sound. only on start up. which is why i find it strange. engine still runs strong. like stated before im about the break down the engine for the gasket set. ill be tightening most if not all bolts to spec. paying extra attention to rotating assembly. anything other suggestions ?? appreciate the tips guys
hmmm, i have heard of piston slap happening on cold start up but wouldnt be present on revving the engine.
Piston slap occurs when the bore of the cylinder has worn down enough to allow clearance between it and the piston causing the piston to actually slap back on forth in the cylinder on a cold startup. It usually becomes less noticeable once it has warmed up and everything has expanded reducing the clearance.
not bueno! im going to start the elimination process with the clutch fan. how could i check that out? the whole piston slap issue? would a compression test bring back any results?
