EXHAUST for sc400
EXHAUST for sc400
hey guys,
I'm in the process of changing my stock exhaust to the following:
-Replacing both cats(with high flow cats) front of engine bay
-Removing center resonator with this(see attached pic).
Got this idea from LS forum.
-Mufflers are going to be magnaflows street series
Has anyone done this?(refering to picture)
Any disadvantages or Advantages???
Is there any performance difference since I'm altering Y-OEM into dual 2.5" pipes?
thanks,
007
thanks,
007
lex400sc has done something pretty similar to what you have planned. hes got all the info up on www.intellexual.net for your viewing/listenning pleasure.
A balance pipe will increase hp for the V8, x-pipe works better than an H-pipe. The balance pipe should be very close to the original merging of the two pipes.
It would appear from the photo that there will be no balance pipe or it will be too far back. This may not be optimum.
http://members.optushome.com.au/acti.../V8Exhaust.htm
H pipe is two banks of V8 exhaust connected by a straight bit of extra pipe - from the bottom the connection looks like a letter H.
X- pipe is what Nascar use - the two pipes merge and separate - looks like the letter X.
Twin turbo exhaust merge at beginning of exhaust after dump pipe anyway and single system after that - no need for x pipe.
thanks
