Where does this vacuum line goes to?
Old 03-21-13, 06:19 PM
JesLet
JesLet's Avatar
Default Where does this vacuum line goes to?
The other end is broken because of brittleness. Trying to figure out where the other end is.
Old 03-21-13, 07:07 PM
jwin
jwin's Avatar
i don't think that is factory. It looks like it could have been for a blow off valve because of that check valve thing. I have a 97 and I have taken my intake manifold off before. I don't remember see that little valve on any of the hoses.
EDIT - actually come to think of it i think that is for the vacuum cansiter under your intake manifold. I remember seeing a little check valve thing on it. i would have to go home and check but I took that off my spare motor and remember seeing it. Check under your intake manifold with a mirror. You should see a canister like the side of a soda can and it has vacuum lines that go to it with a VSV.
Old 03-21-13, 07:13 PM
JesLet
JesLet's Avatar
This is from Aristo GTE, the other lines are connected onto the manifold.
Man, tried to take off the plug from MAP and it was brittle!, wait till i get to the injectors.
Old 03-21-13, 07:15 PM
JesLet
JesLet's Avatar
I should just get rid of that line and connect the remaining lines connected from the intake manifold.
Old 03-21-13, 07:17 PM
jwin
jwin's Avatar
Ohh sorry for giving you the wrong information i didn't know you had an aristo motor.
Old 03-21-13, 07:20 PM
JesLet
JesLet's Avatar
No problem, thanks for helping out though
Old 03-22-13, 03:32 AM
JesLet
JesLet's Avatar
Old 03-22-13, 04:09 AM
JesLet
JesLet's Avatar
http://www.supraforums.com/forum/sho...n.....PICTURES
Brn2drive
GX - 2nd Gen (2010-2023)
57
08-26-24 09:39 AM
McCloudsZJ
18
05-15-19 11:28 AM
TrueGS300
04-15-19 10:16 PM
mad_trbo
GS - 1st Gen (1993-1997)
09-15-10 11:36 AM
brazil
11-26-08 01:12 PM
Quick Reply: Where does this vacuum line goes to?
