1993 sc300 smog/ seafoam help ?!
Old 03-21-13, 11:44 PM
zzobeyyzz
zzobeyyzz's Avatar
Question 1993 sc300 smog/ seafoam help ?!
Sup guys , just needed some input on my situation
I need to get my car smog before I register the sc with the dmv
My car feels sluggish so I went out to buy seafoam. It labels on the bottle that it helps with the emissions test.
Should I seafoam it first then take it on Tuesday ?
Old 03-22-13, 12:35 AM
PseudoK
PseudoK's Avatar
if the cats are already dirty, it would make it much worse and you would fail on HC PPM
Old 03-22-13, 12:37 AM
zzobeyyzz
zzobeyyzz's Avatar
You suggesting j should wait and go take it first ?
Thanks for the reply
Old 03-22-13, 12:46 AM
mattjk
mattjk's Avatar
take it somewhere that will do a sniffer test first without sending info to the dmv. I was able to get that done at a NON test only station. If the mechanic is nice enough, he can read the results and tell you what the causes could be for the failure.
Old 03-22-13, 12:47 AM
zzobeyyzz
zzobeyyzz's Avatar
Okay cool will do thank u
Old 03-22-13, 09:30 AM
3L4jzz31
3L4jzz31's Avatar
This right here, If you think something's wrong there probably is, see what your numbers are first.
In general though seafoam usually helps with smog tests. I've had some friends with borderline numbers that seafoamed and snuck through so it does work just how well varies from person to person. I believe there is also a thread in the DIY thread about seafoaming your engine if you want more info on it.
Old 03-24-13, 06:30 PM
zzobeyyzz
zzobeyyzz's Avatar
Thanks I might seafoam my sc tommrow
2jzNoshizz
03-11-13 04:46 PM
Lexwang07
SC- 1st Gen (1992-2000)
12-08-10 04:32 PM
Xevuhtess7
01-27-10 03:10 PM
Just2fly
16
02-04-08 12:21 PM
sc3000
03-07-05 08:14 PM
Quick Reply: 1993 sc300 smog/ seafoam help ?!
