1jz HP (questions and answers)
yeah i forgot to mention the emanage. I'm not worried about the rev limiter. I'm more worried about the speed cut limiter and the boost limiter that is in the soarer.
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
HKS , make a little electronic delimeter for the JZZ30 Soarer, the Type T6.
In England we had a specialist making the delimeters for our Soarers but he's no longer in business.
Though I'm pretty sure Toan used an Apexi S-AFC to do the same trick.
Either Toan or Manny will know for sure
You can check on ebay and do search ,it works like a afc and has lots of cool features i had one but have since sold it ,you will get a rpm ,1/4mile, rich lean,and be able to adjust you fuel for 3 different boost settings which is how i had mine set up.
Fuel adjust is from idle to 8000rpm, mine was set up for stock, low,
and high boost. There are two versions one for honda which has a vtec setting and the normal one which is the one you want also
look in www.mkiv.com and do a search as it was used a lot by the tt supra folks.
Originally posted by IS200 3SGTE
are the 1JZ-GTE supposed to make the same HP as a 2JZ-GTE but lower torque because of the displacement? i have read and all of them say 280 (claimed on both the 2JZ and 1JZ) but with less torque for the 1JZ.
dunno could be wrong.
