sc400 fluctuations in rpm
Hello all,I am really hoping someone can help me with my sc400.I bought it for 1300 knowing it had a few problems,it had a broken crossmember,and needed a timing belt water pump job. I replaced the broken crossmember,drove it a week or 2 and started leaking oil from front crank seal.Did the timing belt-oil seals[cam and crank]and water pump,idler pulleys and belt tensioner.Drove it 3 or 4 thousand miles started getting warm here in az. so I took out radiator and back flushed with air and water[got out stop leak or headgasket repair crap]out of it.drove it another month or so and everything was great till last evening and it started reving up to 2100rpm and back down to about 1100rpm. I have the service manual on disc but cant find anything related to this problem.Also no CEL and not showing code?Can anyone point me in the right direction ---please.
As of this point in time I been over every single vacuum line under the hood.Can the IAC control go bad?Is it sesitive to water because all this started after flushing radiator.
lateralnw
Performance & Maintenance
12-03-18 07:23 PM
