A/C Compressor seized up / smoking. I want to delete it.
Old 04-05-13, 06:23 PM
FlyRyde
FlyRyde's Avatar
Default A/C Compressor seized up / smoking. I want to delete it.
So since we changed the SC400 to a 2JZ-GE, the AC lines didn't match, and the dude that did my swap left them disconnected. I've driven the car a total of about 200 miles since the swap, had tons of over heats, etc. Today I smell something bad, hear a seizing noise, then see smoke. Shut off the motor, popped the hood, and the AC compressor was smoking.
Can't I just pull the pulley off, bypass it altogether with a smaller belt, and call it a day? Car is stranded on the side of the road right now, so I'm trying to research this first before I get out there in the dark to do it.
All I found so far was this:
http://www.supraforums.com/forum/arc.../t-494189.html
Old 04-05-13, 06:26 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Moved to proper forum.
Old 04-05-13, 07:18 PM
over40driv
over40driv's Avatar
It depends on being able to wrap the new belt around the other pulleys a sufficient amount. Try using a small rope, to see if it will work, then you have to get an exact length belt.
Ryzies
IS - 1st Gen (2001-2005)
04-07-13 06:17 AM
TrueStreet
Performance
01-04-12 11:50 AM
over40driv
09-23-11 07:54 PM
over40driv
07-07-11 06:08 PM
Quick Reply: A/C Compressor seized up / smoking. I want to delete it.
