Aftermarket power steering reservoirs?
Old 04-07-13 | 06:40 AM
Biddles's Avatar
Biddles
Default Aftermarket power steering reservoirs?
Looking for an aftermarket reservoir that will work with my 92 SC 400 1UZFE. Does anyone know where to get one? Preferably not too expensive.
Old 04-07-13 | 10:10 AM
96blksc300's Avatar
96blksc300
I used a mishimoto one with my gte swap. Comes with the both hose fittings the same size... stock configuration is one bigger than the other. Not too hard to remedy though and they run about $50.
Old 04-07-13 | 10:36 AM
Biddles's Avatar
Biddles
This one? What did you mean by stock being bigger and easy to remedy? I really just want a new part in there that works perfectly, and not have to mod much.
Old 04-07-13 | 10:39 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
Whats wrong with yours?
Old 04-07-13 | 10:54 AM
Biddles's Avatar
Biddles
It's extremely dirty. I replaced the PS pump yesterday, and it looks like the rack and pinion and tie end rods will be replaced next weekend. I figured for $50-$100 I might as well replace this old piece of crap too. It is very dirty outside and inside. Has 225K on it.
Old 04-07-13 | 02:18 PM
Vasiliyd's Avatar
Vasiliyd
I feel the same way about mine, planning on painting it flat black though and that should be better
Old 04-07-13 | 02:22 PM
mikevandam's Avatar
mikevandam
I'd just pull one from the yard and clean it like crazy. Cheaper than $50 thats for sure.
Old 04-07-13 | 03:53 PM
estomax's Avatar
estomax
carb clean the crap out of the inside/outside and reuse it.. no point spending money on gimmicky things. unless its in the way of a TT conversion, then yes you need to relocate or find a new one
Old 04-07-13 | 08:50 PM
nkumar92's Avatar
nkumar92
Weapon R makes one for the Supra Turbo, it's made out of aluminum and polished. But it's also $90 :P
Old 04-08-13 | 04:27 PM
Biddles's Avatar
Biddles
There is a filter in the stock reservoir correct?
OMAHA
20
01-05-19 12:57 AM
Sanfou510
08-03-16 01:42 PM
SCereal
05-01-14 02:22 PM
rickytsui
Suspension and Brakes
07-24-13 09:34 AM
Quick Reply: Aftermarket power steering reservoirs?
