Q:50mm wastegate on 44mm flange/tube
04-07-13, 02:07 PM
The wastegate's flange has 50mm(left), the manifold's has 44mm. Will this work properly?
When put together... I don't think there will be restriction on the flow. What do you think?
04-15-13, 05:03 AM
05-06-15, 10:07 AM
Old thread but I also would like to know
If running a 50mm wastegate on a 44mm tube Wil affect anything
05-06-15, 10:26 AM
should be fine, it will be like having a 44mm waste gate though but that should be large enough for most setups.
EL MOSTRO
Performance & Maintenance
34
07-14-12 10:05 PM
ZGagnon
Build Threads
32
06-26-11 06:20 PM
Cleanshots
SC- 1st Gen (1992-2000)
06-07-10 07:14 PM
JZCHAOS
02-22-09 08:46 PM
LexFather
02-20-06 07:53 PM
44 ,
44mm ,
50mm ,
dimensions ,
fit ,
flage ,
flange ,
gate ,
is300 ,
mm ,
opening ,
size ,
sniper ,
tube ,
waste ,
wastegate
