Will I have a problem clearing my 6766 on this manifold?
Just bought a 1jz single turbo manifold. eBay aka Godspeed. Will my 6766 compressor housing clear the first runner? Just had a buddy tell me that it might not clear :/
Did a quick search but couldn't find anything about it not clearing. Previous owner said it cleared his 67mm turbo no problem. But who knows...
More than likely not. I just put a 6266 on a manifold identical to that last night, didn't clear. Needed to put in a 1/2" spacer. Same manifold HAD a 70mm on there that cleared, but the 6266 didn't.
here's a thought. if you have the turbo which the title implies, then why don't you bolt it up and figure it out. real simple like, no?
Here's another thought. If you don't have the turbo, why don't you reconsider choosing a different one because a 6766 will be no fun without cams and a legit tune/fuel/system/management, which I'll assume you don't have because you have a cheapy manifold/wastegate. Up to you, but a 6766 will suck without cams and management.
J J
Performance & Maintenance
13
11-30-05 11:31 AM
