Aristo 2JZGTE running lean
I have a Aristo 2jzgte swapped 95 sc300 6spd.
(car was purchased with the swap complete)
- twin turbo (usdm turbos)
- TTC (true twin conversion)
- supra fuel pump
- Aristo ECU
- fuel cut defender
- MBC set to 16psi
Idle after car is warm i am seeing 13.5-14.5 AFR which seems to be normal, The problem is i am seeing upwards of 16.2 AFR getting into boost and driving not in boost. (afraid to go WOT)
I checked most of the vacuum lines everything seems to be intact. Fuel pressure at 30PSI
The only thing out of place was the K&N crankcase breather popped off and seems to need a cleaning.(could this cause a A/F issue?![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Engine was just compression and leakdown tested a month ago and passed everything with flying colors.
If anyone has any ideas, suggestions or needs more info to help diagnose please help.
I plan to go single some time in the future and an AEM V.2 is on the list. Maybe i should do it sooner than later?
- supra fuel pump
- Aristo ECU
- fuel cut defender
- MBC set to 16psi
