please help have a problem sc400 starts and shut off
Whats up pplz I have a problem my 92 sc400 starts and shuts back off sometimes at cold start but whn I rev the car up yo like 5000rpm the car will idle normal.. has anyone ran into this problem or know why its doin that ?
My guess is that your fuel pump ECU may be going out. Give this a shot: https://www.clublexus.com/forums/per...tures-faq.html
hi Markysc4,
I had the same problem, although my problems were mostly related to warm starts it is just like Kira X said, your fuel pump ECU is probably bad. if you don't feel like buying a new ECU, there is a mod that solves your problem: https://www.clublexus.com/forums/per...tures-faq.html
This solved the problem for me.
Make sure however to use a relay instead of just soldering together the wires. In that way your fuel pump will shut off when you turn off the engine and you can still have ACC on.
/Mike
/Mike
acenase
Performance & Maintenance
04-16-09 04:15 AM
