Powerwashed my sc300 and it isn't running right !
Old 04-10-13, 03:25 PM
zzobeyyzz
zzobeyyzz's Avatar
Exclamation Powerwashed my sc300 and it isn't running right !
So I took my car to the self served car wash and I cleaned my motor
I tried to avoid the spark plugs distrbutor and other important components and still running like crap
I put new ngk spark plugs and still nothing
It shakes violently and drives with no power
Please help u guys !!
Old 04-10-13, 03:28 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
First, moved to the proper forum for you, please post where the thread belongs
Secondly I'm going to show you how to use the site properly so you don't screw your car up again, AND you'll know why it is screwed up because this info is there (IN THE FAQ ACTUALLY).
Bottom line however when washing an SC engine.... just don't do it.
See below:
Attached Thumbnails Powerwashed my sc300 and it isn't running right !-screen-shot-2013-04-10-at-6.27.37-pm.png   Powerwashed my sc300 and it isn't running right !-screen-shot-2013-04-10-at-6.27.50-pm.png
Old 04-10-13, 03:31 PM
Joey-E
Joey-E's Avatar
Should leave your hood open in the sun or something. You probably wet the alternator, cable wires, grounds, coils etc...try going going over everthing make sure nothing is wet and everything is dry.
See below:
+1
Old 04-10-13, 03:34 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
That's not usually the part that gets wet or gives problems. Some disassembly will be needed to remove water from the areas the issue lies. Otherwise it can miss for WEEKS if not properly dried. The area it is at the sun won't have any effect on.
Old 04-10-13, 03:57 PM
2TurboZ
2TurboZ's Avatar
I dont understand what makes someone ever think blasting high pressure water into their engine bay is a good idea.....
Old 04-10-13, 04:52 PM
4thHorsemn
4thHorsemn's Avatar
It's actually not bad for most engines........ Just not Toyota I-6.
Old 04-10-13, 07:11 PM
SoupFlies
SoupFlies's Avatar
This symptom is from water being in with the plugs and wires, remove all of them, make them clean and dry, check if they need replace, leave open, but covered with a cloth so nothing gets in, overnight or so. Avoid driving while it acts like this. If you have old spark wires, take the time to replace them as you do this.
Old 04-11-13, 10:54 PM
Luxor
Luxor's Avatar
I blast my engine all the time, then again, I have an engine cover
Old 04-11-13, 11:52 PM
eknine9
eknine9's Avatar
I use water in a spray mist and then degreaser to clean my engine bay, pressure wash is just asking for trouble. If you want to clean the engine bay you must be careful.
Old 04-16-13, 06:14 AM
slow92sc3
slow92sc3's Avatar
I've pressure washed my sc3 all the time,
I'm careful to not go full blast on areas with wiring that I know will effect the engine/ecu but then again they are all weather sealed connectors... My suggestion is to start reading check engines and also to begin checking for proper spark, starting from coil, to dizzy and individually each cyl wire both ends
Old 04-16-13, 08:24 AM
Ali SC3
Ali SC3's Avatar
you have water in your plug valley and where the wires touch the plugs, the water lets the spark ground out to the block and never makes it into the cylinder. dry out your plug valley and all your plugs and wires.
O. L. T.
47
04-18-14 06:17 AM
NEbiker10
12-06-10 07:30 PM
Halient
10-11-10 10:24 AM
LXOGOOD
Performance
15
05-31-05 07:46 PM
tommym
SC- 1st Gen (1992-2000)
10-20-02 06:47 PM
Quick Reply: Powerwashed my sc300 and it isn't running right !
