Replaced Cam+ Crank seals and still leaking
Old 04-12-13, 06:40 PM
sj408
sj408's Avatar
Default Replaced Cam+ Crank seals and still leaking
Hey guys, so after i ran over a tire i had my car in the air and noticed my undercarriage covered in oil and a steady stream from behind the crank pulley so we replaced the seals in there real quick and cleaned everything off and sure enough right now i got another fresh leak in my driveway.
Anyone know what else behind the crank pulley could leak? Kinda weird
Old 04-12-13, 07:07 PM
chiken
chiken's Avatar
SC400? Engine oil for sure? could be the cooling fan pump?
Old 04-12-13, 07:34 PM
sj408
sj408's Avatar
No, im sorry i guess i should elaborate. I have a built 2j with a t67 single. It seems to be leaking from right behind the crank pulley again.
Old 04-12-13, 08:01 PM
chiken
chiken's Avatar
stick or auto? check for crank walk. get a prybar and try to move the crank pulley forward and back. You should get almost no walk,if you do have play it may be bad news. I have seen a few 2JZ's walk. Even at very low mileage.
Old 04-12-13, 08:47 PM
blk&blu*j
blk&blu*j's Avatar
How much boost? Catch can? stick or auto? using OE Front main or aftermarket
Old 04-13-13, 05:23 AM
lexforlife
lexforlife's Avatar
when you replaced the front main the first time , what method or tool did you use to remove the old seal . if pryed out with a screw driver , were you very careful as to not score the inside of pump housing where seal sits against .
when you inserted the new seal did you use a piece of pvc piping the exact size of the outer most edge of seal and gently tap in squarely , and did you sit the seal flush with the lip of pump or recessed inwards for if sitting to far in , it can leak again
Old 04-13-13, 09:18 AM
sj408
sj408's Avatar
bout 13psi, No catch can, pcv on drivers side vents normally back into intake and i just have a breather filter on the exhaust side.
Automatic, Aftermarket front main by NOK, Lasted 10k miles before showing any issue. Now still leaking after a fresh one
A very reputable local machine shop assembled the engine for me, I had never assembled a 2j before so i figured it was best to leave it up to guys who had the equipment to assemble my engine precisely rather than me just bolting it all together.
I had my buddy put in the seal for me, i came home right when he was done and the seal looked perfectly flush with the outer lip it slide into. Is that not far enough in or? i didnt even think about checking.
pj3840
Performance
08-23-14 07:19 PM
Stak0
12-12-13 08:47 PM
michael024
01-01-12 09:48 PM
SC300_704
14
03-14-10 07:19 AM
acenase
06-08-09 09:56 PM
Quick Reply: Replaced Cam+ Crank seals and still leaking
