Dyno s366, aristo stock ecu,sc300, 12 psi
Old 04-16-13, 08:01 AM
99SC42
99SC42's Avatar
Default Dyno s366, aristo stock ecu,sc300, 12 psi
I went by my friend shop and decided to put the car on the dyno to see what it will do,Thank you Peter Lee ( ISP racing) for the Dyno.
The cars has the followings:
R154, Stock 7m PP with act disc, 3.26 rear end, S366 .91ar divided , divided manifold, Dual Tial BoV, Tial 44mm with 10 psi Spring,4" Exhaust from Turbo all the way back, Fuelab FPR set at 40 spi, Single walbro,-10 feed , -6 return etc..
Car has been running at 12psi because i don't have a boost controler and i am not too worried about it for now!
It made 377 whp on the ISP racing Dyno jet, I will put back on the dyno next week to see what it will do at 18-19 psi and see what she will do!
I will post the dyno sheet this morning.
Old 04-16-13, 08:27 AM
Ali SC3
Ali SC3's Avatar
377 whp is great for 12 psi, keep it up!
Old 04-16-13, 12:08 PM
ashtray
ashtray's Avatar
Have any pictures of your divided manifold and dual bov setup? You're almost at 400 congrats!
Old 04-16-13, 12:42 PM
99SC42
99SC42's Avatar
Thanks Guys!
I really don't have the pics of the manifold , but i can get you the pics of the dual BOVs.
I have one Bov on each side.
I want 450-480whp on this Car with the stock ecu, just another 100whp xtra and i'll be very very happy.
Old 04-16-13, 01:33 PM
97-SC300
97-SC300's Avatar
congrats man, those are great numbers, i want to hear what the s366 sounds like, maybe you can make me a video
Old 04-16-13, 01:46 PM
xspsi6
xspsi6's Avatar
What injectors was this on? Also what form of piggyback did you use on the stock ecu or was this stock 440's as well?
Good numbers considering!
Old 04-16-13, 02:03 PM
99SC42
99SC42's Avatar
Thanks Guys!
Dmitry , this week i will put it back on the Dyno and i will make a video for you!
Chris,
I was on stock 440cc, no Piggyback , no boost controler, no speed cut controler, no BCC, no nothing.
I don't think my ecu has a boost cut on it because, I had 2 springs in the WG and it was hitting 20 psi somedays, so i remove one spring out of the WG (small blue) and left the big Yellow in there which is a 10 psi spring so it creeps to 12 psi .
Old 04-16-13, 02:49 PM
xspsi6
xspsi6's Avatar
That is pretty impressive then^^!
Old 04-16-13, 03:54 PM
kez
kez's Avatar
Wow wow great numbers Quick.
I really want to hear that s366 spool. I don't know what it is but hearing that spool makes CL so excited its like A crackhead hearing,"free crack giveaway!"
Old 04-16-13, 04:00 PM
xspsi6
xspsi6's Avatar
Nothing quite sounds like an s366 spooling other than maybe the HKS t51r
Old 04-17-13, 06:17 AM
GotRiceYo
GotRiceYo's Avatar
Omar, where do you see full boost with the S366 on your setup??
Old 04-17-13, 08:07 AM
99SC42
99SC42's Avatar
Thanks ! More boost and more fuel coming this week.
I will get some better vids on the Dyno this weekend.
^^^ that's correct
I am really not sure , it's a little lazier than my na-t setup but it doesn't bother me I can break boost if needed to.
It's very smoove .
On the way home today i will record a vid on from my phone to give you and idea but remember this is on a gte so it's not Apple to Apple comparison with my na-t setup of your setup .
Compression will give you about 500rpm faster spool than a gte, and E85 will also give you about 500 rpm .
Old 04-17-13, 08:22 AM
GotRiceYo
GotRiceYo's Avatar
Saweet! In for the video..
I wonder how this turbo with the cams would spool on my setup with the 2mm headgasket? Maybe a little to lazy?
Do you enjoy the bigger turbo for daily use? Being that you can def stay out of boost?
Old 04-17-13, 09:04 AM
99SC42
99SC42's Avatar
The thing with 2mm Hg is it's not reliable , it will detonate sooner or later ...
I have always had this Turbo, and its perfect for my setup .
I am in boost 75% of time , i do 90% driving on the hwy and 10 %City.
Old 04-17-13, 01:39 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I love my S366.. quick was the one who told me that I would be very happy with it. ..... and I am!
Lets see the video of it, Omar.
Quick Reply: Dyno s366, aristo stock ecu,sc300, 12 psi
