1JZ Single SC400 bucking and irregular idle
Old 04-29-13, 06:35 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I will man. I appreciate all the responses. I cant believe Quick and Vrank hasnt chimed in, LOL.
Old 04-30-13, 08:46 AM
Ali SC3
Ali SC3's Avatar
whats your car idling at and have you connected the laptop at all?
that video can help and with weather changes it is not uncommon to have to tweak the idle map.
what you want to look at is the idle target, the idle learned value, and then your idle max and minimum.
If the idle learned is positive and at the max number and you still aren't at the target idle rpm's, then the idle map will need to be adjusted up or the max increased so it can get to its idle target.
the default is for the aem to pull and or put in up to 20 degrees of timing when it cannot hit the correct idle rpm.
If you have ever had the aem doing this 40 degree timing swing on you, you would find your wideband doing exactly what you are describing, but there are a dozen other things it could be to make the wideband do that but with shutting off on you with accessories on I can tell your probably idling too low and your a/c parameters need some tweaking.
I have never heard of knock sensors being off either, they are not supossed to be the same for every engine.
the proper procedure is to load the engine up through all the ranges without boost, record the values from the knock sensors to use as a baseline, and then to tune based off of the difference when you add boost. If you do not do that you are just going off of some hypothetical knock values, and the ones in the basemap are conservative so they register "knock" faster.
Old 04-30-13, 01:20 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thanks Ali. To answer your question, I havent connected anything yet. I have been at work since I posted or started this thread. I am going to look at this tomorrow and the rest of the week. I also contacted another friend of mine who worked for Lexus in Nashville. He is very smart when it comes to tuning and figuring out the little things that seems to stun the others. He is supposed to be coming over and looking over a few things. He seems to think it is the TPS going bad causing the bucking and surging, with the help of the IACV. He said they really depend on each other, and when they cant connect together, they try to compensate, possibly causing the issues I have having. He started a new job, and he is not sure on what day he will come over, but he said he will.
I appreciate all the great information on this. You guys are the people I trust. Keep the feedback coming.
Old 04-30-13, 01:49 PM
99SC42
99SC42's Avatar
Damn ! I could be alot of things man.
Log a pull and send me the file, i can have my tuner look at it.
So you are running around w/o knock sensors?
Old 04-30-13, 02:04 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Thats correct Omar. No knock sensors. This was confirmed by another tuner I spoke to over the phone. He told me they generally turn these off when using a single turbo and not using the stock ecu. How do you send this file to you? I understand by email but how by using the AEM? Not real sure how to do that?????
Can you tell me how?
Old 04-30-13, 02:44 PM
Ali SC3
Ali SC3's Avatar
I'm not sure I would even start my car without knock sensors... may want to get them back on there sometime despite what your tuner is saying.
Old 04-30-13, 03:28 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
They were originally on. While tuning the car the tuner claimed the car was losing power. They turned them off. I have never turned them back on. I havent touched the AEM since then.
With everyone having mixed opinions on this, can you explain why you would turn them back on with my setup? Thanks Ali SC3.
Old 04-30-13, 04:14 PM
stockhatch
stockhatch's Avatar
I agree with the others regarding knock sensors. A good tuner can use the sensors to squeeze the most SAFE power out of a combo. Then you are still covered if you get a bad tank of gas, the car gets hotter than normal and wants to ping, etc.
Old 04-30-13, 04:36 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
This is why I love the forums. I have learned so much from this build. Now I need to search on AEM website to learn more about what is in my car and the functions of it. It sounds like I need to take it to the local tuner that I don't trust. My friend Tim should be able to tweak and review the current settings and maps, while I watch ever so closely. I have watched the AEM youtube video like twenty times and made many notes.
If indeed the knock sensors are turned off or bad and in need of replacing, are the 2JZGE sensors the same or has to be one of the GTE's?
Adam, can I call you or call me? 205-482-5533
Old 04-30-13, 05:46 PM
Ali SC3
Ali SC3's Avatar
they just need to be calibrated most likely in the tune if the defaults aren't close. Since you have an ems, you can monitor the knock parameter and if its registering knock with the engine off then they would be bad, but that would be highly unusual. if they are registering higher than normal values, thats actually normal and the defualt is to pull more timing to be safe, but instead of turning it off if it was tuned from a baseline run with knock safe timing, the ems would know that you are not really knocking and it wont pull power. the advantage is that when you actually knock off the charts it will save your motor instead of chugging along.
Old 04-30-13, 06:00 PM
Vrank
Vrank's Avatar
I'm actually learning about the ems right now as I just picked one up. The way it all of the maps work together is very new to me.. So did this start happening a little bit after you got the car back from the tuner? Or did you get it back that way?
Old 04-30-13, 07:05 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
The car seemed to me that it was right. I didnt have anything to compare it to while running an AEM. I have always thought the wideband was off while lightly on the throttle. It has always seemed to bounce around here recently more and more, along with the other symptoms now of jerking/surging, while light on the gas pedal. In all honesty and if my memory serves me right, it has never ran at idle like I thought it should. Another point the tuner brought up was that he had a tough time to set those injectors. I do know they are the largest that will fit in the stock rail for JZ motor, 800 high impedance. I actually went outside to wash the bugs off the front from my road trip and even now at dead cold starting is starting to idle crazy and higher than higher. It almost sounded like it wanted to die, and was stumbling for the first 20 seconds or so, then the idle went alot higher than normal, close to 1300. I have something going on, and wish I had one of you closer to me to educate me in the land of AEM. I would be willing to even pull the check book out, just because thats the way I roll.
Old 05-01-13, 05:28 AM
99SC42
99SC42's Avatar
My opinion
You just need a better Tuner, and a new Tune .
I told you that before, the guy who tuned your car will not touch my lawnmower seriously.
Log a couple runs and email them to me omar5989@yahoo.com
IIrc think you press F6 to start to record and F6 to stop the recording, save it and then send it to me.
Old 05-01-13, 05:35 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Originally Posted by Quicksc4
My opinion
At the time Omar, I was pretty much out of options. My hands were tied. My car had been waiting on a tune for almost 6 weeks before it finally went to Batlground. I tried calling them several times and no one will answer the freaking phone. Why have a business if no one will answer the phone. There is NO reputable tuner around me. There might be one in Birmingham but I dont know too much history behind him. I will email what I have as soon as I get it plugged in and saved. Again the local guy has a very bad reputation in his work and tuning capabilities.
Old 05-01-13, 07:24 AM
Ali SC3
Ali SC3's Avatar
yeah I agree, those all sound like typical excuses for a not so good tune.
to me it sounds like some very simple stuff is off like the idle map, decel fuel cut probably not set low enough (which causes the rev up and down problem), and knock should be tuned.
EMS only runs as good as someone tunes it, and even then it can change with the weather because your tuner only gets it for a few days, but we drive our cars around year round.
Quick Reply: 1JZ Single SC400 bucking and irregular idle
