1jz vvti second fuel pressure regulator under intake manifold?
Hey Guys,
i am just inspecting and learning the 1JZ-VVTI and i can't figure out what this fitting is below the intake manifold towards the back of the motor that the return fuel goes back to the tank through. what is it for and can i delete it?
![1jz vvti second fuel pressure regulator under intake manifold?-08gswo1.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/500174d1683165523t-1jz-vvti-second-fuel-pressure-regulator-under-intake-manifold-08gswo1.jpg)
thanks,
Marko
PS. also if someone could tell me what the blue vacuum solenoid is in the back of the picture, that would be awesome. i am assuming it is the vacuum canister actuation valve which i will delete but i'm not 100% sure.
thanks,
Marko
