R154 - Ridiculously high clutch engagement
^^ Gerry is right. And he's tried many different clutch kits on his gearboxes
The modest couple of single disk Southbend kits I mentioned are good for drivability at lower power levels (365ft-lbs to around 400 ft-lbs or slightly more) and their quality is good at least from all the recommendations I've read. I'll have to get back to you on how long one of their clutch kits last for me at 300whp-350whp. I am playing my GTE setup VERY conservative so that will work for me but probably not for you even with the higher spec discs & pressure plates.
As Gerry recommends, a good twin disk setup on an R154 with higher power levels seems to be the consensus. Yes, they're more expensive but they do the job well and seem to be easier to modulate than the toughest aftermarket single disc kits.
Super Moderator
So instead of going twin clutch spending further on an R154 setup , I would strongly suggest ... save , save , save for now and do it right the in next round of expenditures .... go Tremec Magnum and never look back .
Just my $0.02
With his current +655rwhp power (not sure though what torque) , knowing that every damn owner of a performance car never gets satisfied , he might as well ditch first that R154. Trans internal pressure will be his next problem... spitting fluid from the seals or shifter housing . He maybe one of the lucky ones that will not but 95% of those making over 500rwhp on an R154 had that problem. You don't have to go far , I can name a lot of them on this forum and people I personally know.
Just my $0.02
Just my $0.02
Super Moderator
then save for the clutch setup that comes with pressure plate , cost depends on single or dual . get the shifter , bellhousing . The trans mount can be done if you know someone who welds.
accountant, lawyer , teacher ... whatever ... I will post her quick in your local craigslist , if she objects ...lmaol.
Depending on your R154 .. you should be able to sell that R154 and clutch for around $3k .... tremec magnum is $3200 brand new.
Thanks Gerrb!
I have a degree in both of those fields (accounting and finance), so I know exactly what mindset you're trying to negotiate with.
Think of buying a brand new T56 as a long term investment into your car. By buying the best available transmission now, you'll be saving more money in the long run by eliminating potential transmission problems.
Prices are for everything brand new from grannas:
T56 Swap kit + brand new stock transmission $ 4965
3.5" aluminum Drive Shaft (if bought with kit) +$480
Clutch kit [Clutch masters FX400 (700 tq) + Clutch masters hydraulic throw out bearing] $1195
Billet steel W58 flywheel (if bought with clutch kit) $ 500
Grand total $7140 for a setup that can handle 700 torque to the rear wheels
CD009 with everything new from Collins:
CD009 to JZ adapter kit $1995.99
Brand new CD009 +$1850
Aluminum Drive shaft +$125 (Steel included with kit)
Labor to cut transmission and install adapter +$249
Clutch kit w/ hydraulic bearing (500 tq) + (Included in kit)
Flywheel + (Included in kit)
SC300 shifter adapter +$225
Grand total $4444.99 for a setup that can handle 500 torque to the rear wheels (rated based on included clutch)
All prices are plus shipping. You could source used parts or from different vendors, but that should give you a general idea of what you're looking at.
The following 2 users liked this post by Blkexcoupe:
KahnBB6 (08-22-17),
Studiogeek (08-22-17)
Hi Guys!
Many years later, I was not able to pull off the T56 but I did get an OS Giken TR2CD, twin disk with a hydraulic bearing kit.
Guess what? this is my fourth clutch on this setup and it STILL RELEASES AT THE VERY TOP!
Clutch has been this way from day one. It has 3K miles or so on it.
Still High!
Still High!
Hi Guys!
Still High!
Still High!
It is a "race" style clutch though. At least it's very easy to modulate now compared to those first 500 miles!
