Driveshaft deminsions
Bill, most places go from the center of the u joint up front to the end of the 3 bolt flange. I had my gfs made locally at scotty's on airport. Make sure the rubber part goes with it for balancing. If you still have the auto you can measure lengths of auto vs r154 and the difference is what will need to be removed. Iirc it's around 2 and 1/4 inches, but I'd double check since it's been over a year since I did the last one. This is the guy with the Cressida bTW.
