Neutral Safety Switch
Old 05-17-14, 11:21 AM
kingblack
kingblack's Avatar
Originally Posted by CatManD3W
Bypass Neutral Safety Switch....
Pin 23 of IK2 (White 25 pin) to Pin 6 of IJ1 (Grey 14 pin)
You need to do this or car will not start if you are using Auto ECU
Can you elaborate please? I dont know what pin 23 of ik2 mean
Old 05-19-14, 08:01 AM
Ali SC3
Ali SC3's Avatar
search for jump NSS, there is a picture of that connector its the auto trans connector. instead of just jumping the 2 pins, run 2 wires from them to your clutch switch and wire it to the clutch switch = done.
Old 05-19-14, 08:51 AM
CatManD3W
CatManD3W's Avatar
Those are the body plugs under passenger foot well area where ECU is..
Here is plug IK2
Here is plug IJ1
Look at Gerbb thread it should help you out: https://www.clublexus.com/forums/per...de-easy-5.html
Old 05-19-14, 09:13 AM
CatManD3W
CatManD3W's Avatar
Here is plug IK2
Here is plug IJ1
Look at Gerbb thread: https://www.clublexus.com/forums/per...de-easy-5.html
Old 05-19-14, 05:48 PM
kingblack
kingblack's Avatar
Cool now i understand thanks guys.
Old 10-15-14, 09:27 AM
kingblack
kingblack's Avatar
Default clutch safety connector
Do anyone know the 5 digit part number on the clutch safety connector on the clutch pedal
Old 10-20-14, 05:55 PM
KahnBB6
KahnBB6's Avatar
Received 1,237 Likes on 864 Posts
On the pedal assembly itself or the harness wires with male connector on the end? I don't know it but I could try to look at mine in the footwell with a flashlight if it's just the male connector. The female connector on the pedal assembly I can't get to because of its location, sorry.
Old 10-24-14, 05:59 PM
kingblack
kingblack's Avatar
I found it through seawell lexus already thanks. Im now getting the wires for the female connector
mdv
09-23-14 08:12 PM
milkyninja
01-21-12 09:43 AM
lemmiewink
08-25-08 05:15 PM
Slow_Sc3
07-04-08 12:27 AM
JspecSC3
03-10-06 05:28 PM
Quick Reply: Neutral Safety Switch
