Exhaust Manifold flange warped??
1JZ Single SC400
I have come to the conclusion that I have an exhaust leak. Upon my investigation I found the exhaust flange, where the turbo mounts, is leaking, and you can hear and feel air from 2 sides. After me tearing the turbo off, I found the gasket still in good shape, and I reinstalled it, thinking it might need to be tweaked. Well that was a waste of time and effort. I then found the actual flange where the turbo sits, is actually warped. I put a level measuring device on the flange, and it was indeed warped, almost 1/8inch or a tad more. I have never seen this before or even read about this before. I was so frustrated, I left it apart. I also found three of the bolts that secured the BW to the flange bent, not broken. I retapped them but they still do not seem tight, seem a little loose. I am thinking of having them welded and retapped or.........................?????
I am under the impression of two things happening in the event of this:
1) Can I remove the manifold and have a machine shop file down to make it level again?
2) By doing this, will this weaken the exhaust manifold even worse, being less as thick?
3) But another one?
4) If I buy another one, will the DP have to altered, to sit properly, due to the new manifold?
5) Will the wastegate flange also have to be altered to get this done correctly?
6) I am thinking the last two things is a minimum to have to happen in order to get it right. But are all the 1JZ and 2JZ from different companies the same in aspect of fitment for the turbo to rest?
7) Sell the SC...![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
8) Fix it and be happy, happy, happy....![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
9) I am leaning towards 8, but need some advice........ What to do???
3) But another one?
7) Sell the SC...
Are you saying that your manifold exhaust flange is warped because of heat ? Damn ... how many miles you have put on that manifold ?
You need to find out if it was caused by heat or something else. Replacing it with the same one will just put you in the same situation in the future. If you don't use or get exactly the same manifold then exhaust and wastegate flanges may have to be modified.
1JZ Single SC400
Spoke with Roger for a bit concerning this. He seems to think I can get the flange decked and it should be good to go. I kinda agree. He makes alot of sense. I told him that I would also get the the actual part that bolts to the head checked as well. I did not want to have to change out the other if I didnt. I wanted to keep what I could if all possible. I was afraid by having it decked or trimmed that it will get hotter and warp again. Not in this case I dont believe.
Jerry want to come up on Wednesday and lend a hand??? Could use some small hands in removing this darn thing. I dont think I will have wrapped again either. We will see how it goes.
Anyone else have there manifold flange decked??? The results? ?
Gerry, alot of turbo manifold flanges are warped as well as the the flange for the turbo these issues are due to the enormous heat used when there being welded the flanges will and do contort when cooled it is always a good idea to have the flanges checked by a machinist for a flat and level surface and deck /or machine flat as necessary.
1JZ Single SC400
Roger your prolly right. I will wrap with DEI once I get the manifold back. I will make this a great thread with pictures of course. I will post up my tolerances and what it looks like being warped. I also didnt like the way the flange had so many pits in it. Prolly from previous owner and the left over gasket from his build. I may work on this tomorrow, I may not. The sooner I get it out, the sooner I will get it back and up and running. Anyone got some stock 1jz or 2jz exhaust manifold gaskets lying around???
Currently I have DEI on my manifold and downpipe .. and am about to get a DEI turbo blanket ...
1JZ Single SC400
Thats ok man. We will finally meet one day. Spend some time with the wife. My wife was a little upset today by me spending all day in the garage on such a gorgeous day!! I understand. .
1JZ Single SC400
So you are saying.. keep the wrap ? I was just about to say that I am removing my wrap after Mark mentioned something about the wrap. Isn't the wrap keeping all the heat in the manifold thus overheating it and keeping it glow and causes the warping ?
The wrap will contain the heat making cracking of the manifold an easier task but it does make the manifold more efficient if you keep the manifold hot so you don't get a temperature difference from the exhaust gases and the manifold itself. If you have a quality manifold I would wrap it etc. The tubing is thicker and can handle The head cycle of the turbo manifold. The cheap eBay ones use cheaper grade materials and the tubing is very thin which makes them very prone to cracking.
