transmission mounts help!
So Ive recently replaced my transmission mounts on my AUTO sc300. The old mount had actually cleaved into two pieces.
Anyways, there was a slight noise prior to changing the mounts, now there is a rather noisey clanking sound. It sounds as though as the new mount is actually raising the transmission too high and the driveshaft is the transmission well.
Everything was bolted up correct; Ive double checked specifications, and one of the four bolts snapped while torquing to specs of 19ft/lbs.
any ideas what the issue might be?. ordering a new mount today and dont want to make the same mistake with that
Twista4004
08-25-14 02:00 PM
Eds98LS
03-30-13 08:27 PM
2jzgttegs
02-18-13 06:36 AM
