please help with electrical issue on my sc
OK first here is my problem i was attempting to replace my interior lights with LEDs last night
and everything was going well until it got like 200am and i was having trouble with the seat warmer button lights. i not exactly sure what i did but i think i tried to remove the bulb with a small screwdriver while the thing was plugged in it sparked a tiny bit n now i cant get them to work even with stock bulbs . to make matters worse the ignition ring light stock bulb was stuck and i tried to remove it with a small pliers it broke and i didn't realize it was hot too until it flickered and when it did the foot well light went out along with the ign ring light.
i have already checked every fuse and pulled all the relays after disconnecting battery no luck
i also have tried to put different bulbs in them again . it said in the OM that the dome light fuse controls all the little courtesy lights etc . but my dome light still works > the only thing i noticed is the door part didn't work but not sure it did before i screwed this up any help will be greatly appreciated thanks tom
if you have answers please text or call me or PM me at 502-644-8549 thanks tom
rmittim
09-03-10 08:42 PM
