Electric fan conversion
Old 06-06-13, 03:57 PM
SC3Monster
SC3Monster's Avatar
Default Electric fan conversion
I'm debating on getting rid of the clutch fan on my 300, and switching to either 1 large single, or like 2 smaller electric fans, anyone ever done this, what works best? Also, anyone ever done it without building/buying a shroud? what size fan/fans did you use? Ever have any overheating issues?
Old 06-06-13, 04:07 PM
blk&blu*j
blk&blu*j's Avatar
Why ^^^^^^^^^^^^^^ I'm still on fan clutch and over 900hp. And I live in S FLA. 90+ and 100% humidity and I still have A/C
Old 06-06-13, 05:00 PM
sj408
sj408's Avatar
yeah, IMO don't get rid of it. I ran a dual fan setup with proper relays and temp probe and it was still a nightmare. The stock clutch fan flows like 3000cfm or something with a fan shroud. That's plenty
Old 06-06-13, 05:05 PM
SC3Monster
SC3Monster's Avatar
Just trying to free up room in the front of the motor is all. It wasn't a question of flow, i know the stock fan is more than enough.
Old 06-06-13, 05:14 PM
blk&blu*j
blk&blu*j's Avatar
Electric fans die when you least expect it. clutch fans just continue to spin even with a bad clutch. JMO
Old 06-07-13, 04:53 AM
lexforlife
lexforlife's Avatar
if you are not going to use a oem electric fan setup like is300 or sec gen gs300 fans , you are asking for trouble .. the is300/gs300 flow a ton of air if mounted correctly and plumbed correctly and use a fan controller , the after market ones tend to be problematic and without a good shroud will make a jz motor run hot
Old 06-07-13, 05:23 AM
INTIMAZY
INTIMAZY's Avatar
I'm in the middle of collecting parts to do an E-fan+Supra rad conversion myself. IS300 fans are cheap to find and apparently very high flowing. If it works for an OEM 2JZ setup, it should be enough for a 1JZ setup
You will need a fan controller or EMS capable of handling an extra input. It's not a simple plug and play like many make it seem. The wiring is somewhat extensive.
PHR make a plug and play harness for Supras with IS300 fans, just no idea if it would be plug and play for our cars.
artinist
GX - 1st Gen (2003-2009)
10-06-17 09:20 AM
CrispyST3
SC- 1st Gen (1992-2000)
09-23-16 12:41 AM
98Sc3001jz
SC400 / 300 Classifieds
07-23-14 09:09 AM
922jz
11-14-10 06:56 PM
'95_sc300
04-25-08 03:33 PM
Quick Reply: Electric fan conversion
