weird no idleing run like poop question
hey guys I can figure out many things, i really think a piece of my cat is clogging my xpipe in my exhaust. but incase there is other things that it might be here it goes
my car has been progressively running worse and worse since i heard a rattling under my car. (sounded like the firmiliar broken cat because i hit a curb or something) then after about 3 days the rattling stopped and this problem started happening
so i think the rattling part is clogging the exhaust.
symptoms:
6 out of 10 mornings or start intervals no idle unless I give it just a little bit of gas.
runs like poop unless i give it lots of gas.
will run normal but i definately need to give it 3 times the gas for same results.
if i let go of the gas 6 out of 10 days it will stall. if instead i give it just the slightest gas it stays running
please help.
I'm here for any LS1 swap type questions but i need some help with my 1U
symptoms:
please help.
no im just thinking in spirts
i am trying to diaq without removing the exhaust
some days it starts and idles and other i need to press on the gas just a wee bit
it always runs more slugish than normal
if i come to a stop light it dies, some times
My name is sean Miller, I drink dos ekkes (XX)
I hope the ecu that that guy traded me isn't bad it worked perfect for a month, wher is the iac on this is it right in front of the intake?
I'm defiantly going to check the exhaust, the once jingley sound than now sounds like an exhaust leak but there in no leak, it's coming from inside the exhaust.
But I like the idea of looking at the iac
