Quick crank pulley question
Hey guys, kind of in a bad situation... My crank pulley/harmonic balancer became dislodged from whatever it is connected to down there and now I'm looking to replace the whole thing, on a budget and need it fixed quick...
So my question is whether this crank pulley will solve the issue. http://www.ebay.com/itm/93-97-TOYOTA-SUPRA-NON-TURBO-LEXUS-GS300-92-00-SC300-UNDERDRIVE-CRANK-PULLEY-KIT-/170738317727?pt=Motors_Car_Truck_Parts_Accessories&hash=item27c0cbf99f&vxp=mtr
My crank pulley or harmonic balancer started to wobble and after ignoring it (wobbling noise)
For a few weeks it eventually gave up and separated from the interior of the pulley, so the piece I have now is just a pulley with a big hole right in the middle where it should be connected to the piece still on my motor.... Car is still running but the engine wobbles the car a bit I assume because the harmonic balancer is no longer there. Does all of this sound characteristic of the problem I think it is and will that eBay pulley work to replace the old one without any extra parts??
Car is 1995 Lexus sc300 automatic.
Awesome I"ll check that out.. is it this one?
http://store.driftmotion.com/static/...kpulleyv20.php
So this will replace the whole thing right? Problem solved? It just seemed like what I have that broke is two pieces and this one is one piece. Or is that because mine broke into two pieces ?
It also says it requires a shorter belt? So I need to purchase driftmotions shorter belt to install this? And if i do so will there be any trouble with fitting the shorter belt over any other pulleys?
Thanks for your reply, kind of new to the 2JZ-GE motor and need some guidance.
Yeah, that will work and will need their belt. Figured the other one would too, which is I why I sent you to dm. Thought they had a stock sized one. Be warned, these pulleys aren't great for the engine. It does nothing for dampening, but it's better than what you have now. As for the belt fitting it will fit like stock
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
If you need a replacement used but good condition damper I have 2 or 3 laying around.
LMK
1995, 300, 97, bad, crank, crankshaft, driftmotion, lexus, number, part, performance, pulley, reviews, sc, sc300
