washed my engine, now guess what........
well if your not getting spark your not getting spark, you have to follow the trail from the spark plugs to the battery.
I would like to think that if he put the distributor in wrong it would still spark. and he would get some kind of fire in the cylinders. having the spark plug out and against the block, when turning it over you should see the spark.
if the fusible link was broken then he wouldnt get any electrical response.
if you have replaced the plugs wire distro and cap, tested the igniter and coil, then whats left is the wiring harness and ECU
just got a call from Toyota. they said they've never seen this before. but yeah they said its either gonna be the wiring or the ecu. they are ordering a second ecu to check. if it is then they're gonna have to sell me a ecu. but i honestly doubt it'll be the ecu. Considering the ecu is inside the cabin. i don't think water would've gotten it damaged from the water. but who knows. hopefully its just wiring.
did you try giving it some throttle when starting, it sounds like its trying to start. It could even just be the maf seeing as its right on top and doesn't like to get wet. are you getting any codes on the dash after cranking.
tell tale sign for a bad ecu is not getting the proper check engine light sequence.
with the key in and moved over one click all the lights should come on for a second or 2 including the CEL, If it does not illuminate that is not a good sign either the ecu or bad bulb.
after it illuminates for a second or 2, it should go away or stay solid.
at that point you jumper the pins regardless of whether its lit or not lit, and when you jump it it will light up, and then blink slowly if there are no codes, and faster if there are codes.
If at this point the CEL is not blinking at all and is just solid or doesn't change, or not illuminated at all, that means there is a possible issue with the ecu as the ecu is not responding properly.
I would also check the fuses in the kick panel by the driver side foot, its possible you blew an important one when washing and people always check the ones in the engine bay and forget about the fuses inside the car.
also make sure they check the timing.
ali sc3, i did check all the fuses in the kick panel. at least the simple fuses that you can just put a test light to.
Toyota just called and they said that the ignition fuse is not getting any power. they said it connects to the ecu and the ignition switch. but they don't know why its not getting power. so they're charging me an extra 125 from the initial 125 for more diagnosis as to why it's not getting power.
you just have to replace the fusible link. i was helping a friend with his ae86 who had a similar problem, car wouldnt start after changing stereo (he didn't unhook battery when doing it). no fuel and no spark.. took me a while too because fusible links appear ok but can be burnt out usually, they dont pop like fuses do. gotta take a multimeter to them. they cost 4$ or so.
If you didn't have power ( (+) assuming that dizzy uses positive and negative .. i think it does) at the distributor.. why didn't you try giving it positive and seeing if it cranks.. If the dizzy has a blue and red wire ( i think its that one) it should have positive if it doesn't just test it out. If it cranks follow the wire to the inside of the car and give it ignition power with a fusible link.
Just an idea.
Just an idea.
Hmmm. Who knows? Cause a lot of my connectors if not all of them are broken. They'll stay in place, but there is nothing to secure them in place. They just pull off. So maybe when I washed my engine with the water hose, not pressure washer joey-e, one of the connectors came off. But my guess is it would be towards the rear of the engine. I didn't see anything up front. Or maybe somehow a short was caused that could the fusible link to melt. I don't know. But I did learn my lesson. No more water to the engine.
alright guys. this is where i really really need help. i got a call back from toyota and they said its the ignition relay on the kicker panel that isnt getting power. i got a part number and priced for 280.00 for the part. maybe, just maybe, can somebody check out a spare junction block and take it apart and see if it is repairable inside. or am i screwed and have to buy a new one. the thing that scares me is buying a new one, installing it, and having the junction block go out again because something had to have caused the ignition relay to not get power. but so far toyota said they found everything to be ok. they said all the wires looked good and nothing LOOKED shorted. but that water couldve potentially shorted a wire and caused that to happen.
part number is 8267024080.
Just an idea.
Just an idea.
so there are 3 sensors, each one has one output, and the 4th wire is actually a ground.
There is no power in, and appyling battery voltage to any one of the sensors is a very very bad idea. they do not require a power input to generate their signals, aren't magnets neat?
