should I rebuild or repair my 96 sc300 engine
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Any ideas if i should get another engine put in (was thinking about low mileage twin turbo). or just have the engine i have rebuild/repaired . Also money is gone be a factor. All input is appreciated.
Nes.
it all depends on you budget, a gte motor swap will run you some money, motor alone is 2500 then wiring exhuast intercooler, it also depends on what you want to do with the car, you could rebuld the stock motor an go na-t if thats what your looking to do is go turbo
Thats why i wasnt sure if i should just get the engine replaces or repaired. Also, someoneone on here had a forum thread and he had the same problem, it turned out to be he had to replace the ECU....
If the Ecu is bad it's because of leaking capicators. Replacing the motor with another motor is really a gamble. You don't know how the other owner treated the motor. I would do a compression check first. What are your plans for the car? If you are planning to keep the engine stock then maybe I would get another motor but if you plan on adding a turbo kit then I would rebuild it.
it could be something small or something huge. a compression test will give you a better idea of the ring condition. if it just started leaking and the oil has never gotten to really really low or empty, its probably fine and at 90k you are due for maintenance anyway I would just do a full timing belt + water pump + oil pump.
the oil pump doesn't need to be changed often at all really on these motors, and Im not sure how a mechanic can just say the oil pump, its probably a seal or a gasket and if you fix it soon you can save the motor.
oil + anything hot = lots of blue smoke.
Thanks to everyone that helped me with the smoke issue i had. It turned out to be a oil pan gasket leak, oil pressure leak, distributor oil leak. All fixable withouth having to replace the enginge. Now all I need is where to buy the parts. Any suggestions???
1JZ Single SC400
If you want factory OEM parts, try Carson Toyota or DM. If you want parts readily available then go to local part store, like Advanced, Auto Zone, or Oreilys. Make sure they are Felpro type gaskets. I like them a lot, IMO.
