92 SC4 problems please help
Old 06-22-13, 09:16 AM
cali108
cali108's Avatar
Default 92 SC4 problems please help
My car is acting up, to the point that I really cant drive it.
I've searched for hours. Here's the problem, I start it.
wont rev past 3-4krpm
Idles High 12-1500.
CEL Light on
TRAC Light on
tried to pull codes, but all I get is a solid CEL
So I reset ECU (disconnect Neg terminal) 10-15mins (Still the same solid CEL)
Driving it~ always starts in 3rd gear. in order to take off I have to manually put it in 1st or low and shift up. and overdrive is not engaging. very slow acceleration to the point that it is dangerous,
Horrible gas mileage 8-10mpg
Its sounds like an electrical problem I believe...
things I did ALREADY
Unplugged my MAF and no difference at all!
Checked each coil and when unplugged each one separately, both sides stumbled & ran differently
Also Cleaned the IAC
So I'm Guessing its maybe
MAF?
TPS?
ECU?
here's a video of part of the problem..
and it wont rev much higher than that~
this first started happening a month or 2 ago,
Its like its in Limp Mode. overdrive not engaging & A/C compressor not kicking on, both worked flawlessly when its ran perfectly
awhile back it would do this then sputter and be back to running awsome!
now its just stuck like this plus a lot of electronics are not working like A/C etc...
Any ideas or help would be appricated
Old 06-22-13, 01:54 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Your vid link isn't working...
If the MAF does nothing to the idle when disconnected, I'd cite that to replace. Have you cleaned the MAF recently?
Old 06-22-13, 04:34 PM
durps
durps's Avatar
https://www.clublexus.com/forums/sho...d.php?t=551125. Try these.
Old 06-22-13, 05:31 PM
cali108
cali108's Avatar
I took the MAF out looked at it blew it a little... put it back it was the same.. you not suppose to spay anything on it but compressed air right?
Old 06-22-13, 05:53 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Vid doesn't work for me... Read that thread durps mentioned.
Ya, if the MAF is Karmen vortex type then all you can do is blow it w air. Btw the MAF is an AFM in your case since your car us pre 1995
Old 06-22-13, 05:54 PM
cali108
cali108's Avatar
Originally Posted by durps
good thread, don't know where to start
Old 06-22-13, 05:55 PM
cali108
cali108's Avatar
Ok Im guessing it will say it on AFM
I uploaded the video to youtube should work now
Old 06-22-13, 06:35 PM
SexCoupe
SexCoupe's Avatar
first thing i would check is throttle and transmission cables...seems like a ecu problem...maf wouldnt make it start in third gear, neither would TPS,
Old 06-23-13, 07:14 AM
Vrank
Vrank's Avatar
Your ecu is bad. Before it was going bad. Now it's completely bad.
Old 06-23-13, 07:19 AM
Vrank
Vrank's Avatar
Seriously pull it out and pop it open. You can try getting a q tip lightly wet with isopropyl alcohol and swabbing away capacitor gunk, maybe blow it dry quickly with a keyboard duster. This can help sometimes. Others you have to completely replace the caps for the ecu to return, if it's real bad and has burnt the board you can possibly bypass the burnt spot with a wire. Or get a junkyard ecu and give that a go.
Old 06-23-13, 08:53 PM
cali108
cali108's Avatar
I think I have agree with you guys... ecu I will check it out as soon as I get a chance,
are the ecu's off ebay any good? found a few just over 100.. and what years work 92-94?
Old 06-24-13, 09:13 AM
SexCoupe
SexCoupe's Avatar
yes 92-94 let us know how it goes
Old 06-24-13, 04:36 PM
cali108
cali108's Avatar
It looks good ...
Old 07-03-13, 08:45 AM
cali108
cali108's Avatar
Can there still be something wrong with the ECU? even though there no physical damage?
I tried to start it up yesterday with out any luck, so it doesn't start, I pulled a plug, and no spark...
then 5 minutes later it barley started, just like the video.. wtf still cant drive it... 7 weeks~
Old 07-03-13, 05:56 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
That ECU looks brand new on the inside. Look closely for any leaking capacitors on your original ECU. Is that what you mean by "physical damage?"
Quick Reply: 92 SC4 problems please help
