Oil leak from distributor, HELP PLEASE!
Old 06-22-13, 08:20 PM
maarisssa
maarisssa's Avatar
Default Oil leak from distributor, HELP PLEASE!
Oil is leaking out of my distributor and onto everything under it, including my brand new alternator. I've already tried replacing the o-ring, distributor cap and rotor and it still continues to leak. Please help! I don't know what else to do.. BTW, i have a 93 sc300 auto trans.
Old 06-22-13, 09:12 PM
jbrandon
jbrandon's Avatar
It is a leak from where the shaft that holds the gear that meshes with the cam is at. Time to replace it!
Old 06-23-13, 01:57 AM
maarisssa
maarisssa's Avatar
Thank you for your response, jbrandon!! But I dont understand, replace what? And how?
Old 06-23-13, 07:38 AM
nlc
nlc's Avatar
Replace ur distributor. Mine did the same n I jus replaced it..no leaks now. Gl
Old 06-23-13, 06:26 PM
maarisssa
maarisssa's Avatar
really? when i tried to read up about the problem before posting this, i always read that usually just replacing the distributor itself would not stop the leak.. because i changed my o ring, cap & rotor all at once and next day, same leak, all over my alternator. I was hoping i didnt have to replace the distributor itself. i would post pics to show but im not sure how haha
Old 06-23-13, 09:53 PM
jbrandon
jbrandon's Avatar
The 2 red circles are places that oil can also leak through and there is no repair for it. If you replaced the oring on the outside and it still leaks then one of these 2 spots are the issue and you will have to replace.
Attached Thumbnails Oil leak from distributor, HELP PLEASE!-w01331738828oes.jpg
Old 06-24-13, 10:08 PM
maarisssa
maarisssa's Avatar
jbrandon, what are those called? or how do i replace it?
Old 06-24-13, 10:52 PM
Bflatsharp
Bflatsharp's Avatar
Replace the whole distributor.
It took me 2 alternators before I figured it out.
Old 06-24-13, 11:23 PM
jbrandon
jbrandon's Avatar
Unfortunately you have to replace the distributor, no fix for it. Buy a used distributor or a re-manufactured one, that is the only thing you can do!
niteridrIS
IS - 1st Gen (2001-2005)
09-19-17 10:51 AM
91fox94gs3
GS - 1st Gen (1993-1997)
08-23-16 11:49 PM
eknine9
11-21-13 06:02 AM
ALLWiTE2JZ
08-13-13 09:00 AM
0nePutt
Maintenance
10-25-09 02:17 AM
Quick Reply: Oil leak from distributor, HELP PLEASE!
