Very light throttle hesitation/jerking
Sounds exactly like my tps issue, had a brand new tps that was no good from toyota. took a year to figure it out until i hooked up a datalogger and seen no tps signal.
i used to be able to drive however long i wanted.... even 8 hours and it would not have issue. As soon as i started and restarted vehicle i got the light throttle jerking you speak of..... while trying to cruise it would buck back and forth but soon as i mashed the pedal it went away.
bet its tps....
bet its tps....
bet its tps....
bet its tps....
Yes, it comes on with key-on engine-off and when I jumper E1 and Te1 it flashes repeatedly showing no codes. I even induced a code (unplugged MAF) to make sure the CEL was working correctly and it threw the corresponding codes related to the MAF being unplugged.
by what your saying, sounds identical to the issue i had. The super light throttle makes your car buck but if you get in it it "seems" fine? bet if you got a new tps on there youd noticed a world o difference.
At the time a friend who worked at a local tire shop had the solus scanner that the whole chain passed around. Another friend picked up a snap-on scanner and it has the obd1 toyota adapter.
hi guys i am having the same problems with my 93 sc400 has about the same mileage 117k and i did everything swint did my self. only thing i got mine with the idle problem its just getting worse every day i disconnect my MAF SENSOR and it runs much better i have a check engine light and a traction light when i disconnect it. I take it to the Lexus dealer and they are telling me to start with replacing my transmission like am stupid or i have money like that they r just throwing parts at cars. O I have too throttle plate in mine one is open all the time and the other is close until i rev it out is that normal? i love this car would love to fix the problems.
1JZ Single SC400
I am still leaning towards three things: bad coils, IACV, and or ignitors...
Here is a great DIY for really cleaning the IACV. I would do this first. While you are at it, replace the bearings, and then put back together.
https://www.clublexus.com/forums/per...acv-sc400.html
MuGGzyx
Performance & Maintenance
15
04-20-14 10:08 PM
