2jzge na-t build for 500hp
Its a 1992 2jzge non vvti that has 160k miles on it but it was rebuilt with acl race bearings on mains and thrust,klevite 77 on rods,npr rings,and a 2.4mm cometic head gasket. With a hx35 turbo and other things like AEM ems v2 with a speed density setup.
After consulting MULTIPLE parties about HG this year i have came up with the need to go to a better HG choice of which is a OEM TT HG. I will also go to coil on plug thanks to lookevo for the lq9 coils and hardware. I will be keeping the 2jzge dizzy instead of the 7m cps. In the mean time im still looking for a turbo that will suite my needs of 500hp for a daily driver and possibly 600hp on e85. So here are some pictures of what has been going on
this build will be drawn out, im doing transmission,rearend,all of the suspension bushings, strengthen the rear subframe, head gasket,bigger radiator,oil filter relocation,bigger brakes,and some other stuff im forgetting. but my bank account is hurting right now so ill have to give it time to recover before i buy alot of stuff again. so the cheapest and easiest will be suspension bushings first
well ive got a few ideas bouncing around on the turbo subject
-keep the hx35 and do water/meth and shoot for 450hp
-hybrid the hx35 with a hx40 compressor
-just swap the hx35 for a hx40.
-drop a grand on a PTE 6266 1.00AR which will be full boost when the cows come home. 4500rpm-guessing
i really like having full boost at 3500rpm. its so street friendly and no gear changes on interstate to pass,or hills,etc
http://forum.aempower.com/forum/inde...,29417.75.html
http://forum.aempower.com/forum/inde...c,30646.0.html
WOOOHOOOO FLEX FUEL FOR EMS V2
