Rebuilding 2jzge
If you go with gte pistons don't get a gte gasket. If you use ge pistons use the gte gasket. The piston swap is the better choice but most do the gasket because its easier. Since ure doing rings I woul just get gte pistons and ge gasket
2jz, 2jzge, engine, hydrolocked, management, motor, na, rebuild, refreshing, reliability, replace, start, swap, turbo, wont
