SC300 Hesitation, Idle Issues, Rich Exhaust Smell, etc....
#46
I am still awaiting arrival or repaired ECU.....it has been over 2 weeks now since I sent it out to LexTech....when I contacted them before purchasing the repair i was told it would take 2-3 days for the repair. Lextech is not very responsive to emails nor easy to get into contact with. I just want my ECU back so I can drive the car.
#47
#48
#51
I've had similar issues, but never looked at my ECU, I should do the same.
Pretty much in the same boat as you, I changed o2 sensors and got another maf, still same, mulimetered all other sensors and they all checked out okay.
I want that damn ecu to arrive at your house already, the suspense is killing me! It's times like these that make me despise EFI lol subbed
#54
Got the ECU back today.....
Unfortunately it did not solve my problems. I went out for a test drive for an 1 hr to let it warm up and do a few pulls on the engine. Was running decent for the majority of the time and then the last few minutes I couldnt even get it to stay running with my foot in the gas....it was smoking pure white smoke out of the exhaust really bad. I had to sit on the side of the road and keep cranking it to it finally fired up and it was driving really bad...The engine seemed like it was down a cylinder and had no go to it at all, I managed to limp it back to my house and I had a solid check engine light and I am getting codes 21,28, and 31. The problems just seem to be getting worse every time. At this point I am ready to scrap the motor and save up for a swap.![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I have been looking at my options and I tossed between a 1jz/r154, 2jzgte swap and use my w58 trans or rebuild my current engine. They are all relatively similar in cost when you add things up.
Not sure which approach to go...
