1JZ SC300 will not rev past 2000 rpm STILL!
Old 01-28-14, 08:55 AM
  #91
OBEEWON
OBEEWON's Avatar
Harness has been in for a few weeks and the car will not even start anymore.
For some reason at ACC the car cranks. At start position it just clicks. Strange. The only thing that has changed is the new Tweaked harness.
Mike is attempting to talk to tweaked about it.
Old 01-28-14, 09:06 AM
  #92
99SC42
99SC42's Avatar
Grounds or starter
Old 01-29-14, 05:26 AM
  #93
Vrank
Vrank's Avatar
does your cel at least function properly now?
Old 02-26-14, 10:24 AM
  #94
OBEEWON
OBEEWON's Avatar
Found out why no cel.
So Mike said he's been trying for weeks to get Tweaked on the phone to fix the harness. He couldn't so he took it on himself and got it fixed. So now the car starts and doesn't flood.
I got to say I'm not pleased with Tweaked. I probably wouldn't buy again. The quality is good but not worth $1000. Especially since there was a mistake and they did not make enough effort to correct it.
So even though the engine started it's still backfiring. Mike did a leak down test and two intake valves on cylinder 5are stuck open.
1j is non interference and the timing has always been spot on so the odds are oxidation from sitting got the valves stuck. So I found a method to free them without removing the head. You take the cam out, and put rope in the. Ylinder. Put that cylinder to TDC to push the valves up. Soak them in lube and use a drill to spin them free and done. I hope to try it.
Old 02-26-14, 11:50 AM
  #95
Vrank
Vrank's Avatar
Might as well do valve stem seals while your in there. I would. Funny, but I'm pretty sure I said you wasted your time on that harness.
Old 04-07-14, 08:17 AM
  #96
OBEEWON
OBEEWON's Avatar
So it turned out to be the harness. What I purchased wasn't exactly plug and play, some wiring was mixed up.
There were no stuck valves.
The end to a nightmare.
Old 04-07-14, 08:21 AM
  #97
Vrank
Vrank's Avatar
So what was the leak down issue with cyl 5?
Old 04-07-14, 09:48 AM
  #98
OBEEWON
OBEEWON's Avatar
...Ummm....
I did not do the leak down test, therefore I don't have an answer to that maybe a mistake?
Old 04-08-14, 03:44 PM
  #99
tiguy99
tiguy99's Avatar
Read this entire thread from page 1. Happy you finally got it sorted out. How's the car driving now?
Old 04-10-14, 08:41 AM
  #100
OBEEWON
OBEEWON's Avatar
Thanks man. It drives well, I just have to rebuild my LS calipers to fix my low braking point issue and get an alignment and I should be at the track soon.
Old 08-31-15, 08:58 PM
  #101
AMA0627
AMA0627's Avatar
Bringing an old thread back from the dead, but. Could you go more into detail about what was wrong with your engine harness? I myself am having very similar issues and i'm sure others are too. A somewhat detailed description of what was fixed on the harness would be awesome.
I understsand the tweaked harness was messed up but what fix actually got the car running?
I'm hitting a weird "wall" at about 2k RPM's also. This is a JZX110 DBW swap into a GS300 on the JZX auto trans. Car is stock except FMIC/exhaust/ intake filter
Any help would be appreciated before I start throwing money at it. I'm going to try to pull the codes, if any, tomorrow to see if there is anything there.
-Adam
Old 01-28-16, 11:28 PM
  #102
AMA0627
AMA0627's Avatar
bump, any help would be greatly appreciated!
Also codes were o2 sensor and MAF sensor, replaced them both and same codes.
LuisC1389
06-12-18 04:01 AM
owner232
11-27-16 04:49 AM
ToyotaPro
10-14-13 08:04 PM
RyanV
Lexus Vehicles Classifieds
14
10-31-11 09:06 AM
ttsleeper
12
04-11-07 10:56 PM
Quick Reply: 1JZ SC300 will not rev past 2000 rpm STILL!
