head light wiring diagram?
so heres another thread by this noobie.... so not thinking i took apart my head lights and have to do the rear as well the previous owner installed ricer lights heads and tails and put them together using a splice job with some electrical tape so i want to do it right with some solder and shrink tube but i didnt take pictures....... also my gauge cluster would show rear brake light failure when i hit the breaks it then would stay on any ideas on this? brake lights worked.... when i had my key that is
love the 97 look hate my ricer look im pretty sure it can be done id have to see both light harnesses maybe dice and splice?
If you don't have hyperblink you just pull the bulb on your cluster for the rear brake lights.
this happens on 95 going to 97 tails, you get the brake light warning, but no hyperblink.
92-94 going to 97 tails I want to say if i remember right they get both the brake light warning and hyperblink.
If you have hyperblink you can fix that and the brake light warning by getting the tail light module from a 97+ car and replace your with the newer one.
Some have done workaround methods of adding or removing bulbs to match the amount that were on the older harness instead but the all around better way is to get the newer tail light module. 95-96 you don't get hyperblink so if you don't have the new module you can just pull the brake warning light, but obviously it wont warn you about brake lights being out anymore.
beels1
03-21-04 08:05 AM
