Jzz30 fan/clutch same as jza80 fan/clutch?
I need a fan, clutch, and pulley for my soarer swap since I am ditching the hydro fan. I know a 2jzgte pulley will work. I also know a soarer clutch and fan will work. My question is, are the jzz30 and jza80 fans and clutches the same?
Thanks jz gurus!
Thanks jz gurus!
a supra mkiv fan will fit. I have a sc300 shroud and fan clutch with a supra fan blade. Works perfectly fine. The 2jzge fan blade will hit the radiator pipe.
Yeah either shroud will work the only difference is the blade itself.
the tt blade moves towards the radiator to clear the upper water pipe , where the na has the upper water pipe on the driver side and goes straight to the radiator.
I have been reading a lot and it looks like the GTE fan will clear with a stock rad, but barely. I'll give it a shot, but it appears an ls400 clutch paired with a 7mge fan is the combo the would work best for me. Keep in mind my car is equivalent to a MKIII Supra, so it is a different animal.
EDIT: Okay, I think I want to try a GE fan setup. I can shim it just a tad and be good to go AFAIK. One day I'll figure out what I want
