1jz wont start
I have a 91 Toyota soarer 1jzgte. It sat for 5 weeks while I was at work the battery died. So I jumped it with the truck, run great, went and got gas. Go to start it the battery is dead again. So I got a jump. And all was good again.went home let it sit for a couple hours, it started right up. Now the next day battery is fully charged and ready to go. I go turn the key, but no crank. No spark. I can hear the abs pump, fuel pump. But the car just won't crank over. What's going on..
Battery is fully charged and wont crank, look for all connectors on starter are properly hooked up and not loose or disconnected. Motor terminal and solenoid is where i would start off with. Motor is grounded i think and solenoid should have 12V when you have key in start position IIRC that is.
Good luck,
-l0kz
Good luck,
-l0kz
