Power steering pump for 1999 SC400
Team,
I need a pump for a 1999 SC400, cant seem to find one anywhere but the dealer. Anyone purchased a 98-2000 pump recently, where did you buy it from. Reman is fine, though i think all are reman at this point.
Yes, it was for my 2000. My mechanic had no problems finding the pump for the pre-98 SC400s, as he had ordered one and it did not fit on my 2000 when he tried to install it.
As you can see from this pic, the only difference is that the LS400 pump has the reservoir attached to the pump itself, whereas the SC pump is connected with a hose off the pump.
LS400
![](http://www.alltoyotalexusparts.com/products_images/27202_01.jpg)
SC400
![](http://www.alltoyotalexusparts.com/products_images/90147_01.jpg)
Just removed that bottle from the new/rebuilt pump, and installed the bracket connecting the old/original remote bottle/reservoir to the new/rebuilt pump and it bolted right on.
LS400
SC400
LS400
SC400
LS400
SC400
I received a 1999 LS400 pump, but it has one extra hole than the SC400, right next to the High pressure line exit. Did your Mechanic just put a stop in that hole and connect up everything else?
OK, after doing some reading on the LS400 and the prior year SC, it seems the ACV was directly connect to the PS pump, on my car it is connect to the high pressure PS line. So I should just be able to plug that hole and be ok..I will let you know and post pics of what worked or did not work
LEXXIUM (11-12-18)
LEXXIUM (11-12-18)
And Biddles, the dealership option is outrageously overpriced since you have no choice other than to dump around $700 on a brand new unit vs. $150ish on a rebuilt LS400 pump.
So I installed my LS400 pump this morning works like a charm. Switched the bracket on the back, plugged the hole for the vac switch with this part dorman 785-422.
![Power steering pump for 1999 SC400-image-1744406267.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/301960d1461125758t-power-steering-pump-for-1999-sc400-image-1744406267.jpg)
The bracket and the need for that plug is the only difference between the two.
1999 LS400 pump
![Power steering pump for 1999 SC400-image-2764621695.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/301961d1461125758t-power-steering-pump-for-1999-sc400-image-2764621695.jpg)
SC400 1999 pump
![Power steering pump for 1999 SC400-image-1392116045.jpg](https://www.clublexus.com/forums/attachments/performance-and-maintenance/301962d1461125758t-power-steering-pump-for-1999-sc400-image-1392116045.jpg)
Thanks for the info on the pump.
1999 LS400 pump
SC400 1999 pump
Are you still in a position to get this pump? If so, how much, how soon? I'm in Port Charlotte, FL Thanks! RichB
GX470GT
04-21-11 09:27 PM
livesc400
Performance & Maintenance
08-31-05 03:52 PM
