Turn key and most horrific loud grinding sound ever.
So my sc nightmare continues new symptom showed up. No codes. Starter was removed and tested and checked out fine what the he'll is it now.....
It's much louder almost like a automatic glock. Flywheel looks good and all the bolts are still in it. Some times it grinds(90%) some times it doesn't (10%). Either way it doesn't start and makes me wanna burn the *****.
If something is grinding, there should be evidence of it on the starter teeth, or the ring gear. Post up a video so we can hear what you are hearing, as the glock example does not help me to diagnose. If everything looks good and you still have issues, I would replace the starter since that is easier and cheaper than replacing the flywheel/flexplate.
Cyclenby
SC- 1st Gen (1992-2000)
08-14-10 09:18 AM
meanboy
04-22-08 02:22 PM
