Idle gremlin again
Old 10-10-13, 07:22 AM
MajorSloMo
MajorSloMo's Avatar
Default Idle gremlin again
So I'm having idle issues again. No idea whats causing this what so ever. Before the car would idle really low and then I fixed it and it was right where it was supposed to be , but now when I let the car warm up from cold its up around 1k rpm and gradually comes down to around 800 to 600 rpm and maintains that. Now it goes up to about 1k rpm, slowly drops down to 800/600rpm, and then drops down to like one bar above the 0 mark. What could cause this? It doesn't sputter or stall or hesitate or anything at all.
Old 10-10-13, 08:24 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
A TPS that needs calibrating, a dirty/faulty MAF, a dirty IACV, then the usual, spark plugs/wires, dirty fuel injectos ect
Old 10-10-13, 10:03 AM
Ali SC3
Ali SC3's Avatar
you change the battery or reset the ecu lately? usually when it starts to change how it idles.
either a small issue like sc400slide said or your ecu needs to relearn again after another reset.
Old 10-10-13, 06:52 PM
emoFTW
emoFTW's Avatar
I have the same issue except on a 1J. Guess I'll try calibrating the TPS.
Old 10-10-13, 06:53 PM
MajorSloMo
MajorSloMo's Avatar
I'll run some injector cleaner in my next tank up. Its possible the IACV is dirty I mean its stock from 1992
flosssc
08-05-15 08:49 PM
Austinheal
02-11-14 10:54 AM
redforeva
18
09-22-11 02:51 PM
aumsc400
12-31-05 05:56 PM
Synergy
08-22-02 03:24 AM
Quick Reply: Idle gremlin again
