Heater Problem SC400 1995
Could be the heater control valve on the fire wall, mine went out and the heater no longer worked, test the solenoid with a multimeter it should test somewhere around 42ohms if its good, if its bad, it will be testing OL.
Bypass the heater control valve. Mine didn't work, and I did this, it still works. And it saves you from buying that 200 dollar part.
https://www.clublexus.com/forums/att...e-img_1937.jpg
https://www.clublexus.com/forums/att...e-img_1938.jpg
Oh, & next time, please search, it will yield many results.
Thanks so much. Is the solonoid located on the drivers side of the firewall? My husband is into Classic American cars, been a mechanic for 40 years, but the Lexus is quite different. I don't have a repair manual but need to get one. I do appreciate your information.
Thank you so much. We have a 37 Chevy Coupe and a 56 Ford PU. Both go to cruise in's. Quite a bit of difference from the SC. Although they have T-Bird and Vette engines, still a lot easier to work on than the SC. I bought the SC in July, owned a 92 and foolishly sold that. My bucket list included another SC. They are so gorgeous and fun to drive. I am going to the garage right now and find that solonoid and test it. Also will locate the person you mentioned and see if I can get a CD. I looked at the manuals online. Good Grief! You are right. Huge.
Once again, many thanks.
Will this fix work for a car that takes forever to get the heat going, and only really produces heat when the engine is under a load?
My heat works, sort of. However, it will take a good 5-10 minutes after starting the car to get it hot, and when I come to a stop light the car starts blowing cooler air.
bypass the heater control valve. Mine didn't work, and i did this, it still works. And it saves you from buying that 200 dollar part.
oh, & next time, please search, it will yield many results.
This may sound like a dumb answer but.......
Do you have sufficient coolant in your radiator?
I had the same problem, heat only when moving from 60 up, no heat at stop lights.
I topped of the radiator and the heater was like a furnace.
Ideally, your car should get to operating temp relatively quickly and stay there so long as the car is on if your thermostat is working properly. If your thermostat is stuck open or you don't have a thermostat the engine will take forever to heat up and will have trouble staying at operating temperature when not under a load.
If you're noticing these symptoms it's time for a new engine thermostat, should be able to find one online for $5-$20.
Otherwise your coolant might be low or there is air in your system. Check your coolant level and run the engine with the front of the car raised up and the cap off your radiator. While it's running, turn the heater all the way up, squeeze the coolant hose periodically , if any air bubbles start coming from the radiator that is air that shouldn't be in the system escaping. Keep going until no more bubbles are escaping, then top off your coolant, and obviously put the cap back on your radiator. Go for a drive and test out the heater afterwards and watch your engine temp gauge to make sure everything is normal.
Thanks to eknine9, I resolved my heater problem in short order after checking everything else I could think of. The symptom was simply no heat, no matter what the settings. About three years ago someone suggested it might just be low on water and, although I was skeptical, that turned out to be the problem. I had forgotten that solution until I read a recent post by eknine9 repeating the earlier diagnostic. I checked and it was indeed low on water and after topping it off the heat is ON!!! By the way, there were no other symptoms to point to low coolant level - the engine temperature was entirely normal throughout. Club Lexus help was greatly appreciated!
Been having this issue as well. Today I bypassed the heater control valve and it didn't fix it. So I parked on a hill, opened the 17mm bleeder, and filled reservoir. Took a gallon and now heat works amazing. Jus confused to loss if that much coolant :/ oh well it works in happy
