HELP!!! 1jz turbo downpipe???
Old 10-21-13, 07:27 AM
djway
djway's Avatar
Default HELP!!! 1jz turbo downpipe???
Need some help fellow sc owners.. I just put a 1jz in my sc300 and in wondering what downpipe do I need for the factory twins to run to my factory exhaust????
Old 10-21-13, 07:43 AM
187's Avatar
There is a factory downpipe that will fit from a soarer. I'm not to sure how easy it is to find one but they are out there.
if you google an engine set you can see what your looking for. I think they sell some stainless stuff on ebay aswell.
Old 10-21-13, 07:50 AM
djway
djway's Avatar
Thanks.. I been searching but can't find a stock soarer downpipe. Do you know if the supra mk4 or mk3 downpipe will work on the sc?
Old 10-21-13, 07:53 AM
187's Avatar
I'm pretty sure they are very different. Have you looked at the stainless ones on ebay? There not a bad option and I know people have reviewed them on here.
*edit some poeple have uses a dp off an mk3 and had it modified at an exhaust shop. But if you have the piece that comes off the twins that is kind of triangular you might as well get a downpipe made.
Old 10-21-13, 08:07 AM
djway
djway's Avatar
Yea I have but it didn't really tell me in the description for the part if it worked on the sc..thanks for yur time ima keep searching around
Old 10-21-13, 09:01 AM
wirelesstj
wirelesstj's Avatar
buy a 3 inch y pipe off ebay if your running twins. no sense in buying a stock downpipe if your looking for dp, just go 3 inch
Old 10-21-13, 09:25 AM
SquatedSC
SquatedSC's Avatar
I ran a generic supra 3" downpipe and changed/made a flange to fit the 1j turbos. you can buy just the 1j turbo flange from driftmotion.
Old 10-21-13, 09:34 AM
fried_rice
fried_rice's Avatar
I made my own with the driftmotion flange. Selling it for cheap, but shipping is the problem, because it's long.
Old 10-21-13, 11:47 AM
Vrank
Vrank's Avatar
Not if you marked it, then cut it in half. One weld is cheap. Shipping would be more reasonable that way
Old 10-21-13, 12:18 PM
99SC42
99SC42's Avatar
I got a Dp to bolt right up to the twins and bolt up to you SC300 factory exhaust.
Hit me up.
psgill
07-17-15 06:03 PM
SC3NAT
10-24-13 11:10 AM
BeeMiX
Northeast
05-21-12 01:39 PM
MrFairlady
12
07-31-11 11:51 AM
individualOLD
SC- 1st Gen (1992-2000)
24
10-06-02 09:10 PM
Quick Reply: HELP!!! 1jz turbo downpipe???
