Coolant Leak on top of engine
I'm attempting to locate a leak on the top of my engine. It's getting in between the valve covers soaking my plugs and wires. From what I could see it looks like it's coming out of the hex bolts between the cylinders. Do these leak coolant or would it be coming from the heater hose or throttle body hose
Do you know if the hex bolts actually leak coolant or not?
i have not heard if those hex bolts leaking coolant. It could be one of the two hoses, best way is to take the throttle body and flip the throttle body over and see which hose is leaking. you can get access to them without taking it off, but easiest way to service the hoses is to get the throttle body off
kizzle
Performance & Maintenance
12-27-18 09:57 AM
bleasdell
SC- 1st Gen (1992-2000)
09-28-15 01:40 PM
