Rear Trans mount??
Originally posted by LEXBOGGY
Has anyone ever replaced their rear trans monunt? I think that is where I'm getting a vibe when i let off the gas.
First inspect if the tranny mount has colasped. If so, jack up the car and get a floor jack to support the tranny. Unbolt the tranny mount from the cross member support. Then remove the cross member. That will expose the tranny mount. Remove it from the transmission, and perform the replacement in reverse order.
It's that simple!
-scott
Thanks I'm ordering the part to day.
Please take into consideration I said that *could* be the problem. It's best you inspect the tranny mount before you buy the part.
-scott
