sc300 ac compressor compatibility?
Old 11-11-13, 10:16 PM
Golden95SC
Golden95SC's Avatar
Default sc300 ac compressor compatibility?
Hey so i think my compressor is out. When i turn it on nothing hapens and the ac light starts blinking, then when i turn it on and give it gas it squeals louder and louder as i give it more gas.
So heres my question. I have a 92 sc3, are all sc300 compressors compatible?
I remember on my 95 the ac lines were differen than a 93 lines,so im not sure if its the same for the pumps. im not sure if pre 95 lines are all the same and post 95 are all the same. Anyways im looking for a replacement now so will any sc3 pump work?
Ive heard that soarer compresors are the same
Lmk
Thanks
Old 11-12-13, 01:25 AM
SC4ME
SC4ME's Avatar
i have a 92, my a/c stopped working. in 95' the us made r134 mandatory but i dont think the sc got it till' 96'. however if u wanna get specific it depends on the month in the year your car was manufactured. not sure about soarers but it sounds like your compressors gone. u can pick up a used one for $100 bucks or less at a junkyard. i retrofitted 134 lines on my r12 and forced a/c pro in but theres a leak on mine so it didnt last. winters here anyway. good luck!
Old 11-12-13, 01:06 PM
Golden95SC
Golden95SC's Avatar
i believe my car already has the conversion, i got it filled not to long ago professionaly, no leaks . the vaccum was perfect. so when we filled it and tried to start the ac thats when i knew it was the pump
so do you think il be safe if i get a compressor for 92-94?
from what i can see a 98 pump is in fact different from older models, im not sure when the change starts, but on ebay i can see pictures, one coming from what looks like a 98 99 with a vvti motor, the ports for the lines is the same 2 holes but with only 2 pins, the older model compressors have the same 2 holes but they have 4 pins
but it just dosnt make any sense, the 4 pin ac pump is described for 94-2000
and the 2 pin pump says it works 92-2000
as you can see here
this is the 4 pin compressor, the add describes it for 94-2000
and here is the 2 pin compressor
this add describes it for 93-98 supras and 92-2000 sc, it also says its a re manufactured oem unit
and heres another listing
this one says it for 94-2000. it shows the car thats its from and its a vvti 97+ sc.
any ideas? il keep digging to find an answer
edit:
ok so heres a compressor from a 97
im not sure is the 2 pin compressor is the newer style nor do i know what year they started them in, but from the pics the 4 pin compressor looks like its from a 95-96 since thats the front bumper it has on
Old 11-12-13, 01:36 PM
soarer13oy
soarer13oy's Avatar
the pins are removable
Old 11-12-13, 01:42 PM
Golden95SC
Golden95SC's Avatar
i see, but what about the holes that are going to be left due to removing them?
is that an issue?
Old 11-13-13, 05:49 PM
SC4ME
SC4ME's Avatar
just stay on the safe side and get a compressor for the same year as yours...or try the autoparts store, theyre system knows what fits exactly.
Old 11-14-13, 01:40 AM
soarer13oy
soarer13oy's Avatar
the studs will align the lines with the compressor.
thebadz32
05-30-12 06:03 AM
cartmill
SC- 1st Gen (1992-2000)
05-10-10 04:44 PM
Quick Reply: sc300 ac compressor compatibility?
