Help !!! sputtering, no power, red cats,shaking.!!
Old 11-14-13, 01:32 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Originally Posted by Murco
That "running rich" smell could be from clogged cats. That would recycle fuel through the evap system and overwhelm the filter for the system. I've never seen this happen on a Lexus and I'm not intimately familiar with the evap system on an SC but the glowing cats sure lead me in that direction!
The OP said that he was burning a ton more fuel then normal, so I'd suspect Fuel control. In the mere future, the Cats will definitely need replacing, obviously.
Old 11-15-13, 12:11 AM
2jznosht
2jznosht's Avatar
Originally Posted by SC400slide
Yes, but he needs to track down what is causing the "running rich" issue before he replaces the cats. The honeycomb inside will just melt again and clog if he doesn't fix the unburned fuel issue entering the exhaust.
I have a 93 and it was just age that did mine in. The rich smell could just be coming from the cats not functioning
Old 11-15-13, 01:56 PM
1995sc3
1995sc3's Avatar
Update he styill cannot find out what the problem is, the muffler shop said my cats were plugged so they deleted all the cats even the one right fter the headers
things are fine-
injectors
timing
distibutor
ignition coil
compression
tps
any ideas i have no car please help anyone in socal have a ecu that might have one i can borrow if thats the problem ill gladly buy it
Old 11-15-13, 02:51 PM
1995sc3
1995sc3's Avatar
Hel,p please i do not have a car they cannot find the problem
Things that were checked
Injectors
timing
dis
ignition coil
compressison
fuel ecu
tps
is there anything else that might be holding it back please help you guys i appreciate it
could it be my general ecu if so could anyone in socal have one laying around i could borrow and pay for if it is my ecu. Ill gladly buy it if my ecu is actually the culprit.
Old 11-15-13, 07:20 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Could very well be your ECU. Did you ever do the 12v mod on the Fuel control?
Old 11-16-13, 04:22 PM
SCstone
SCstone's Avatar
just throwing em out there but charcoal canister and fuel filter/pump, fuel regulator. iacv. no codes?
on a n/a you need cats for back pressure and such.
Old 11-25-13, 03:02 PM
1995sc3
1995sc3's Avatar
fuel pressure is at 40psi and 50psi at full throttle is that ok?
Old 11-25-13, 03:21 PM
1995sc3
1995sc3's Avatar
No my mechanic did not want to do that, he checked fuel pressure and he said it was fine because its at 40psi at idle and 50 at wot is that fine?
Old 11-26-13, 07:33 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Another thing you can do is rip open the main ECU and check closely for leaking capacitors.
For the future, fuel pressure should be between 38 and 44 PSI. At WOT, 50 is fine. (older SC models go a little higher)
Old 11-26-13, 08:55 AM
Murco
Murco's Avatar
You've checked the coils, distirbutors, timing, and the cats are off... How about the ignitor (ignition control module) and plugs? Has your tech done a "smoke" test (pressuring the system with a smoke generator)?
Old 11-26-13, 11:43 AM
CatManD3W
CatManD3W's Avatar
Check the Main ECU under the carpet on the passenger side foot well...Most likely your capacitors in the ECU need repaired...Do you know someone close by that you could swap out ECU's with. If not you could try replacing the ECU....Im sure someone on the forums has one for sale
Old 11-26-13, 03:29 PM
2jznosht
2jznosht's Avatar
I'd try the 12v mod and also take a look at the ecu
ajonesy
19
08-26-15 01:20 PM
cms123
11-24-11 12:44 PM
UofACATS
26
12-22-07 12:16 PM
FireCode
07-11-05 04:37 PM
Dx3
01-19-05 09:33 PM
Quick Reply: Help !!! sputtering, no power, red cats,shaking.!!
